Adjustable Ride Height, Magnetic Ride, and Front Lift System - What You Need to Know
  • Adjustable Ride Height, Magnetic Ride, and Front Lift System - What You Need to Know
    Thanks to Josh Holder for reviewing the adjustable ride height as it relates to Magnetic Ride Control and Front Lift System with me this morning. The photo below shows the adjustable spring seat that allows almost two full inches of adjustment to the ride height.
    The following are important details as you consider how you want to spec your 2020 C8 Corvette....
    1) The adjustable spring seats are only available on the Z51 optioned Corvettes. You can NOT adjust the ride height on a non-Z51 C8 Corvette.
    2) The adjustable spring seats on a Z51 optioned Corvette are identical regardless of whether you order Magnetic Selective Ride and they are adjusted manually in the same manner as well.
    3) THIS IS THE BIGGIE...if you option your Z51 Corvette with the Front Lift System, you will ONLY be able to adjust the REAR spring seats because the lift system replaces the adjustable spring seats on the front of the car.
    Great info - thanks!
      I had made an error on my initial post so please review the change that I made. Thanks!
        Thanks - still good info, but not as great as before.
          However, if you get that E60/Z51 combination, you can still you the Z51’s adjustable spring perches to adjust your rear ride height — and that is how you can do some visual height adjustment to your car — as well as some corner weighting.
            Unacceptable John. You go back over there and tell em to fix it.
              So if you want to lower the car you have more need for the front lift system, but won't have a built in easy way to do that?
              What are "Z51’s adjustable spring perches"?
              What would be the most appropriate way to adjust the ride height with aftermarket mods (i.e. least amount of negative trade-offs) in the mag ride + E60 scenario? New springs?
                Big negative against the front lift system IMO. If I'm wanting to adjust the stance of my car it's likely I'm going to want to be able to adjust the front.
                So, procedure is to take the weight off the wheel and use special tool on the adjuster nut. What's the tool?
                2020 C8 Corvette.D.O.B 2/03/2020
                Shadow Grey Metallic on Black
                2LT, Z51 + MRC. GT1 seats.
                Spectra Grey Tridents.
                Carbon flash mirrors and spoiler.
                  The typical single claw spanner wrench. Pretty much every performance outlet sells them that deal with suspensions and coil overs. Pretty sure GM will sell them at double the price.
                    I have worked on bikes, this adjustment method is vintage bike territory
                      Now that's disappointing. Thanks for bringing it to our attention, but too bad GM designed it that way.
                        I have worked on bikes, this adjustment method is vintage bike territory.
                        Heh-heh, I've got the Campagnolo version of that tool sitting in a toolbox in my basement. Actually used the corresponding tool for the fixed cup just a couple of weeks ago. Always pays to hang onto old tools.
                          That campy tool must've cost a fortune!
                            What's your feeling on this John? I know you wanted to lower the car somewhat (both ends) and I know the lift system was important to you to travel to the places you wanted. Are you thinking of giving up one of those? Or figuring out some other approach (aftermarket) ?
                              I bought it along with some others a long long time ago when I was working summers as a bike mechanic. Took advantage of the employee discount.
