Find out your C8’s Order Status by asking!
Information provided to MidEngineCorvetteForum members, and with great thanks to Corvette Ed for answering your inquiry requests in our sticky’d “The C8 Order Inquiry Status Thread” in our “Purchasing Section.”https://www.midenginecorvetteforum.c...inquiry-thread
Red engine cover matches valve covers
  • Red engine cover matches valve covers
    Red engine cover matches valve covers.
    Click image for larger version  Name:	20190823_095503.jpg Views:	0 Size:	2.38 MB ID:	63025
    Delivered 5/29!: Scarlet Fever 2021 2LT HTC, Red Mist Metallic Tintcoat, two-tone Naturalw/ suede inserts, Mag Ride, Performance Exhaust, MRR 755 Gunmetal wheels
    meyerweb, since the RED cover may be on constraint for who knows how long, I'm not holding my order up waiting. I'll have it painted. How hard do you think it would be to remove the "Corvette" plates to paint the cover? Another thread previously indicated there weren't any push pins on the underside. Think they're just glued on??
    2020 C8 Stingray Coupe 2LT; LBR Metallic / Natural Interior; GT1 Seats; EFY; Silver Hash Marks; E60-Front Lift; ZZ3-Engine Pkg; NPP-Exhaust; Edge Red Calipers; Edge Red Eng Cover; EYK; VQK; RXH; WKQ; SC7; GNOCC charter member. C8 arrived at the dealer 8/10/20
      I checked that, too. The other post was correct. I couldn't feel anything underneath either. Probably glued.
        Would it be feasible to remove it without bending/putting a crease in them?
          Couldn't do anything but guess. The silver planks seem to be fairly thick, but I have no idea what kind of adhesive they're attached with.
            that looks a bit to gimmicky too me. The black looks more solid and expensive, IMO. In black, it looks less like a plastic cover.
              Or strictly friction fitted with two or three male plugs (each side) fitting into top of engine cover holes.
              Z06 coming late this summer: Hypersonic Gray HTC, two tone blue interior, complete high wing/aero package. CCB’s, with every piece of visible carbon fiber available to us. Lifetime, annual contributors, and 24 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
                I'm not sure the red plastic cover is thick enough to have retaining holes that don't go all the way through. I did try to see if I could pry the silver plate up with my fingernail, but couldn't really get a good purchase. Best wishes to the first person who tries to pry it off and see what happens.
                  After seeing this photo I changed my build order, no longer getting the Red Engine Cover. Talk about bait and switch, the pictures on the configuator are bright Red. I'll do it myself and speed the process up on the delivery.
                  72 Corvette T-Top, 85 928, 04 CLK 500 Conv, 20 C8 2LT Z51 White/Red HT
                  August 20, 2019 status 1100 / February 18, 2020 status 2000 / February 19, 2020 status 3000 / September 8, 2020 status 3300 / September 21, 2020 status 3400 / October 15, 2020 status 6000 / October 15, 2020 left deposit for ZO6 @ MM / Ron Fellows - COS Graduate - April 23/24, 2021
                    I ordered with the standard black engine cover. As I stated from checking out the cut away engine at Carlisle, there aren't any push pins retaining the brushed alum plate with lettering and I don't want to attempt to pry off the brushed alum plate that has the embossed CORVETTE lettering to fill in with red paint. I will just remove the entire engine cover which is held on with 5 bolts...... then fill in paint the lettering and replace the entire engine cover.
                    3LT Coupe, Z51 Torch Red with two toned Red/black interior. 5VM visible CF ground effects, Carbon Flash wheels, engine appearance package and Carbon Fiber interior trim. Mag Ride control. Red Calipers. VQK Splash Guards. Carbon fiber: Steering wheel, mirrors, High Wing, Door handles & boomerangs; Rear Diffuser with vertical diffuser fins; A Pillar; B Pillar; Rear Hatch Side Vents, as well as top camera surround piece and lower under glass piece; Engine bay surround pieces; and front grill trim.
