CORVETTE TODAY #154 - Meet Betty Skelton, First Woman Of Firsts
We honor the first woman inducted into the Corvette Hall of Fame, Betty Skelton. Cindy Sisson, CEO of GSEvents and Pam Miller, Co-Producers of the documentary Betty Skelton, to highlight Betty's illustrious career. https://youtu.be/qCYEyOeh9Y4; https://podcasts.adorilabs.com/corve...skCcoYH9ekEi82 The list of Betty's accomplishments are too many to list here. She broke barriers that no woman had crossed prior to her. After watching and/or listening to this episode of CORVETTE TODAY, you'll understand why Betty is the first woman to be inducted into the Corvette Hall of Fame. Enjoy this insightful episode about Betty Skelton on CORVETTE TODAY! Listen to the podcast, watch the YouTube video, join the Facebook group, sign up for email notifications and shop in the Merchandise Store at: www.CorvetteToday.com
Battery protection
  • Battery protection
    Is the battery protection option just a tender or does the factory do a more elegant installation and plugin?
    I assume the CTEK I have for my C7 can be used with the C8. It is "just a tender" the exact item of which can be bought cheaper in the secondary market. Don't know if the C8 tender will be different. Good question.
      I suspect it is the same as the C7 battery tender, just with the C8 logo.
      I use the C7 battery tender very consistently, but IMHO there are better CTEK units available than the GM-licensed one, and at similar (or lower) prices.
      CTEK also sells a cig lighter adapter, which I've used with another one of my CTEKs on my C7 - worked great, and I've used the RECONDITION mode with that CTEK unit on my 5+year old C7 battery, once a year.
      I plan to use that (more advanced) CTEK with my C8.
      Every time I get in the car, "I fire up the willing engine, responding with a roar", thanks to CTEK.
        Yes, there is a 12V plug in. I doubt if the car is equipped with just that plug-in if the option is not checked. Since the battery on the C8 is accessible under the "shelf" behind the "frunk", it may have easier access than was the battery on the C7 that was buried beneath the carpet in the right rear of the hatch. Yes, you can buy for less money, but the option is a "clean" installation and IMO, worth the $100.00.
        GD0 Accelerate Yellow Metallic; 3LT; HUE Natural Napa Leather; AE4 Competition Sport Seats; FA5 CF Interior Trim; Z51; FE4 Mag Ride Suspension; E60 Front Lift; Q8Q CF Open Spoke Wheels; J6F BR Brembo Calipers; RCC ER Intake Cover; DTH CF Racing Stripes; ZZ3 Engine App Package; VQK Splash Guards; ERI Battery Protection; R8C Museum Delivery
        Proud LTM NCM.
          Good question. I will add it to my NCM 25th Question Ask list. Thanks whl3!
          2023 Z06: Hypersonic Gray HTC, two tone blue interior, CCB’s, 3LZ, E60, and with every visible carbon fiber option order-able including wheels. Lifetime, annual contributors, and 25 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
            John, on one of the pictures of the "frunk", I thought I saw the little flap covering the 12V plug-in adapter on one of its side walls!
            Proud LTM NCM.
              That's a good point, but don't all C7s come with the trunk cig port for the battery tender, regardless if the battery protection package is selected?
              I seem to recall that the C8 pics I've seen also have a trunk (or frunk) cig port.
              Fortunately, John will get the definitive answer.
                I think I've seen the port in a picture but don't remember where I saw it. It is on the passenger side of the vertical wall that runs along the wheel well.
                1966 coupe - Sunfire Yellow / Black
                2004 Z06 - Millennium Yellow / Black
                NCM Lifetime Member since 2003
                  Car battery used to be 12 volts output,
                  Then due to all the current drain with the controllers having functions stored in a temp memory
                  newer batteries put out 13 volts and when engine running with Alt voltage is about mid 14 volts
                  Depending on this new B bus system and a lot more controllers drawing more current load
                  Question is, is C8 battery higher voltage output ?
                  if so older battery tender may not work correctly since it senses voltage levels to determine it's output to battery
                  So maybe worth finding this out to determine if off the shelf 3rd party tenders can be used or not
                  Maybe the photo I saw made it look like, but almost seemed the C8 battery was a bit longer ?
                  As to a tender I still prefer as with my other Corvettes is hardwire from battery posts wiring that then is routed to a outside under corner spot
                  so tender can be plugged in there and no need for opening/closing a hood, window, or hatch
                  Corvettes owned, wrenched on and raced since 1975:
                  1974,75,77,84,87,89,91,93,94 ZR-1 & 1999 Mallett 435
                    12 Volt plug-in like my C7 is all I need. Nothing more. Probably need the tender less since my C8 will come equipped with OEM AS tires.
                      Sorry but this doesn't make sense. It's the alternator that puts out when the engine is running.
                      The resting rate of my newish battery is 12.4 V.
                      The charging voltage of my tender is 13.5 V and the voltmeter in the car will show 13.5-14 V when running.
                      These are nominal voltages that have been around almost forever with "12V" cars.
                      Oh and my car is a 2010.
                      2020 C8 Corvette.D.O.B 2/03/2020
                      Shadow Grey Metallic on Black
                      2LT, Z51 + MRC. GT1 seats.
                      Spectra Grey Tridents.
                      Carbon flash mirrors and spoiler.
                        It is common for me since the C5s to see 13.2ish volts with the key off, parked and at the battery posts as shown below
                        When car is at idle, no HVAC or headlights on, common I see via OBD-II is around 14.4ish volts, as shown below
                        My point is people assuming their existing tender will be fine, might not in that theirs was designed to output from 1/2 to 1 AMP maximum
                        Since C8 has even more controllers, that have settings into temp memory then when a C8 is parked there could be even higher current draw
                        and requires a newer tender that has a higher current output so people may want to think about this and decide do they use their old tender,
                        get the one as a GM option
                        Or find a 3rd party one that meets the current draw C8 requires
                        Even more draw could be this GM auto controller software logic via wireless that means some controllers do not stay in a sleep mode and
                        when updating is done other controllers may wake up and draw more, plus the Onstar that is on
                        Click image for larger version  Name:	003.jpg Views:	1 Size:	477.2 KB ID:	61618
                          So many questions.........I’ll spend $100 and let it go. Who ever ends up with my C7 will get the C7 tender and me well I’ll just smile at the C8 when it gets plugged in with its new tender..... easy.
                          2023 Z06 #5 locality and smiling
                          2020 Stingray Triple Blue Coupe
                          “Cindyblue”
                          6000: status : R8C on August 5,2020 @10:00 🥳🍾
                          2020 C8 Stingray; 3LT ; GS7 Elkhart Lake Blue ; HTO Twilight/Tension interior; Z51;FE4 Mag Ride; C2Q dual roof ; FA5 interior vis CF; ZZ3 engine appearance; Q8T Spectra Gray Tridents; RCC; J6E yellow Calipers; VQK Splash Guards; EYK Chrome Exterior Badge package; R8C
                          2014 Stingray Laguna Blue : SOLD
                            yes, all C7's have the port in the trunk regardless of whether you buy the ctek
                              Your “newish” battery is only charged to 75% if your battery voltage is 12.4 volts.
                              3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
