I just measured the front end clearance of my Honda Fit, which is the lowest car I own. It is 4 and a 1/2 in, which is an inch lower then the C8. I don't think clearance will be a problem.
Clearance is higher than a Honda Fit
I rubbed all the time in my C7. Expect the same of C8. It will be even worse if you spec the ground effects package as that will lower the front end too vs. base.
Axle lift for the win!Last edited by gthal; 07-28-2019, 06:23 PM.2020 C8 | Torch Red | Z51 | 3LT | Carbon | Comp Seats
2016 Porsche GT4 | Black everything ... sold
2016 BMW M2 | Blue | MT ... sold
2014 C7 | Torch Red | Z51 | 2LT ... sold
Of course it was on a grass field but I looked at that rubber airdam and it sure did look like it was touching the recently mowed grass..
im sure it must have been the grass as opposed to pavement...
i sure wish that e60 was available on the 1LT but I have to draw the line somewhere as a responsible adult...
responsible adulthood is over rated...
you guys that get E60 are going to be so cool...
still keep in mind the back end is at regular height I believe...never want to bottom out that rear engine or transmission...its been stated its located low so that the top of the engine is below the top of the rear tires..luckily the dry sump oiling system with three scavenging pumps will probably keep is safe...
i believe if gm ever moves to a corvette awd sport cuv...that lift system will be on both front and back suspensionsLast edited by JB; 07-28-2019, 06:07 PM.
- 1 like
Originally posted by Klinn View PostHowever, the approach angles may be more than a little different between the two cars (and not favoring the C8).Delivered 5/29!: Scarlet Fever 2021 2LT HTC, Red Mist Metallic Tintcoat, two-tone Naturalw/ suede inserts, Mag Ride, Performance Exhaust, MRR 755 Gunmetal wheels
- 1 like
Originally posted by WillRockwell View PostI just measured the front end clearance of my Honda Fit, which is the lowest car I own. It is 4 and a 1/2 in, which is an inch lower then the C8. I don't think clearance will be a problem.Rocket City Florida- 2001 ZO6 - 2013 427 Vert - 2020 Stingray
Outbrain
Adnimation Footer
