Corvette Today: Meet The E-Ray Integration Engineer Cody Buckley
On this episode of CORVETTE TODAY, you'll meet one of the fresh, new shining faces of the Corvette team. Cody Bulkley (pronounced Buckley) is the Performance Integration Engineer for the new Corvette E-Ray. Now, you're probably saying to yourself, "What is a Performance Integration Engineer?" https://youtu.be/jAlb0CCv6eI?si=YbBYl7OqiAkWWq-h; https://podcasts.adorilabs.com/corve...Yj6dBD5JYh43W0
Cody explains that when he sits down with your CORVETTE TODAY host, Steve Garrett. Plus, Cody is the guy who did that awesome "Cyclone Spin" in New York City's Rockefeller Center on January 17th, 2023 when the Corvette E-Ray debuted.
Cody's excitement and enthusiasm for the new E-Ray is blatantly obvious in this episode of CORVETTE TODAY...it makes me want one!
You can also see the video of the Cyclone Spin on this new episode of CORVETTE TODAY!
Lowering a C8 Z without front lift
  • Lowering a C8 Z without front lift
    Is there a way to lower a Z06 C8 with the nose lift? I was told that the max lowering is 3/8th inch since apparently the C8 Z does not have lowering bolts. Is this true. Has anyone else been able to lower their Z a bit more perhaps around 3/4 inch?
    I made a mistake. I meant was there any way to lower a c8 Z without the nose lift by more than 3/8 inch.
      Yes there is. I would contact Ciocca Performance or Paragon Performance and they will explain the options you have. I believe there are three of them for a Z06 with the front lift option.
        John
        I meant lowering without the front lift.
          Removing the air in your tires should do it! And it's free! (sorry, I couldn't resist)
            Did you look to see if the Z06 doesn't have the lowering bolts?
            2023 Z06 Red Mist HTC Red Calipers / C-Flash Mirrors and Spoiler / Black Exhaust Tips / Front Lift / Black 3LT / CF 1 Interior / Stealth Trim / Red Belts and Stitching.
            Red Mist C8 Z51 traded for his big brother
            Atomic Orange C6. Plenty of engine and suspension mods. Gone, but not forgotten
            Member, Old Dominion Corvette Club https://www.olddominioncorvetteclub.org/
              There are no lowering bolts on c8z or any c8, that was on c7
              Thanks,
              Steve
              Just received my 2023 Z06 June1 2023
              Changed my build from z07 to z06 on 4-21-2023, order accepted status 4200 as of 5-30-2023. Will be Hypersonic Gray HTC Built 5-22-23, received June 1 2023
                On cars w/o front lift, the shock spring seats are adjustable by ~ 20 mm up or down. Basically the same idea, even if the terminology wasn't spot-on.
                  Yes you just need the spanner wrenches. Fairly easy diy
                  Thanks,
                  Steve
                    Lowering without the front end lift is super easy. You just need the coil over wrenches sold by Paragon Performance. You can watch this video here to see how to do it. The process is the same in the front as it is in the rear if you do NOT have a front end lift.
                    Check out my YouTube channel for all kinds of Corvette content:
                    www.youtube.com/horsepowerobsessed
