While we wait for the official reveal of the Next Generation Corvette, it is safe to assume that the C8 body panels will be made of the same materials that are currently used for the C7. These are:
1) Sheet Molded Composite (SMC)
2) Carbon Fiber
3) Plastics
Continental Structural Plastics is the supplier of the SMC body panels that are used on the C7 and will continue to supply SMC body panels for the C8 according to information that became available in 2016 when the Huntington County Tab revealed details pertinent to the Next Generation Corvette related to the expansion of the CSP Huntington Plant. http://www.huntingtoncountytab.com/c...-two-new-lines
The process employed in producing the SMC body panels can be seen in the following video from CSP.
While the Corvette body was made of fiberglass for first 20 years (1953-1972), sheet-molded composite began to be used in 1973.
From GM Media:
2) Carbon Fiber
3) Plastics
From GM Media:
Starting with the third generation in 1968, the body parts were manufactured with a press mold process, whereby the fiberglass material and resin were shaped in a die-like tool that produced smoother parts more quickly. It was a significant advancement in forming technology and laid the groundwork for a change in the body panels’ material in 1973. That year, the composition changed from conventional fiberglass to sheet-molded composite, or SMC, which was composed of fiberglass, resin and a catalyst formed under high heat and pressure. The ratio of resin to fiberglass was reduced with SMC, while the fiberglass itself was a bit coarser. The new material helped produce panels that were smoother right out of the mold, resulting in higher-quality paint finishes.
All Corvettes since 1973 have used SMC body panels, but the material composition has changed dramatically, featuring less traditional fiberglass and more lightweight plastic. The early SMC material created parts that were stronger and more rigid, but more brittle. As SMC technology and production experience evolved, Corvette engineers were able to alter the material composition and the body parts’ specifications to trim the Corvette’s curb weight. Mostly, that happened through making thinner body panels, because SMC was denser and stronger than conventional fiberglass.
