So as we all know, the C8 manual calls for 93 octane. But since that is very hard to find in the day of state emissions requirements, can we use a high quality octane boost (torco or boostane) to supplement 91 (or even 87) octane without voiding warranty or causing engine damage?
Official C8 Owners Manual, Build and Price, Visualizer, Pricing, and Ordering Information
2021 C8 Visualizer: https://visualizer.chevrolet.com/ui?...US&channel=b2c
2021 C8 Official Build & Price: https://www.chevrolet.com/performanc...nd-price/color
2021 Order Guide: https://www.gmfleetorderguide.com/NA...D=22048&type=0
2021 C8 Brochure: https://www.chevrolet.com/content/da...te-catalog.pdf
2021 Owners Manual: https://www.chevrolet.com/content/da...s%20Manual.pdf
2021 Official Track Prep Guide: https://www.chevrolet.com/content/da...reparation.pdf
2020 Owners Manual: https://my.chevrolet.com/content/dam...CCUSRHpUv0Rawg
2020 Coupe/HTC Build & Price: https://www.chevrolet.com/performanc...d-price/config
C8 GM Videos: https://www.midenginecorvetteforum.c...urman-criswell
GM’s C8 Info Site: https://www.chevrolet.com/upcoming-v...ation-corvette
Octane Boost to Supplement 91 Octane Fuel
Welcome Ls1eater. A couple of things to assist you. First our Corvettes does not require 93 octane. Our Corvette motors of this and a couple of earlier generations will run fine with 91 octane. There are some Corvette motors going literally over 500,000 miles without 93 octane fuel and never needing even their heads removed.
GM does not recommend octane boosters., To salve your wallet, to save your motor, I would never use one can myself. Just enjoy your Corvette on the highest octane you can get where you are (without buying above what regular gas stations have) and not to worry a bit. On our Corvettes, we I have hundreds of thousands of miles with very rarely over 91 or 92 (best we get where I live) — never a single motor issue.GBA Black; HTO Twilight/Tension interior; Z51 & Mag Ride; E60 lift; 5VM visible carbon fiber package; 5ZZ high wing; FA5 interior vis CF; ZZ3 engine appearance; 3LT; Q8T Spectra Gray Tridents; J6N Edge Red Calipers; SNG Edge Red Hashmarks; VQK Splash Guards; RCC Edge Red engine cover; VJR illuminated sill plates. Lifetime, annual contributors, and 23 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
- 2 likes
Unfortunately my state does not carry the recommended 93, with 91 being the highest available but with reduced performance.
I'm fortunate to have 100 unleaded race fuel available in my area and do add 2.5 gallons of 100 to a 8.5 gallon 91 fill bring the octane to 93/94.2020 C8 #3760 Torch Red - Jet Black/Red Stitch Interior
Z51 3LT - Mag Ride - Front Lift - Body Color Accents - Torch Red Calipers
PPF + Ceramic Coating - HydroCarbon Torch Red Engine Cover
FabSpeed HJS Hi-Flow Cats - Carbotech 1521 Ceramic Low Dust Pads
BVI Billet Aluminum Cross Bars - Attack Blue NanoFiber Air Filter
Gwatney Manifold W/95mm Ported Matching Throttle Body
Gyrodics 2-Piece Floating Brake Rotors
Vossen Evo-5 Forged Brushed Gloss Clear Monoblocks 19x9/20x11.5
- 2 likes
Those are good options for those who choose but candidly other than on the race course if then and other than from time slips at the drag strip your butt dyno is not going to be able to tell the difference between your power at 91 vs 92 vs 93 octane.
Outside the West Coast, when 93 is unavailable, its due to elevation. The higher the elevation, the thinner the air. Which means, compared to sea level, engines are operating at lower cylinder pressure (except some supercharged and turbocharged cars). So your car at 3500 feet and up does not need 93.
The same is true across the board. Where 87 octane regular is commonly sold at sea level, in the mountains it may be 85.
- 2 likes
I agree with comment about not using an octane booster. There is a specific warning in the owner's manual about fuel additives and all of the octane boosters I've seen contain those additives.
The manual also states 91 octane is acceptable but the engine may have reduced power and fuel economy (I don't think you'd ever be able to tell unless you were running a timed event).
Don't use less than 91 octane.2020 C8 Stingray Convertible - Torch Red - Natural Dipped 3LT - Z51 w/MSRC - Front Lift
Exact words in the C8 owners manual. 91 may be used but, "with reduced performance". 😞
I have used Boostane Premium in my 600 hp Mercedes AMG engine with great success. It does make a difference in power so if you can only get ahold of 91 and don't want the "reduced power" this is a good alternative. But if you use any octane boosters and you use them regularly, the one downside is you may need to change your spark plugs more often than the recommended timeframe.
Originally posted by ZonaZ06 View PostExact words in the C8 owners manual. 91 may be used but, "with reduced performance". 😞
Here is what the owner's manual says about fuels:
Prohibited Fuels
Caution
Do not use fuels with any of the following conditions; doing so may damage the vehicle and void its warranty: .
For vehicles that are not FlexFuel, fuel labeled greater than 15% ethanol by volume, such as mid-level ethanol blends (16–50% ethanol), E85, or FlexFuel.
Fuel with any amount of methanol, methylal, ferrocene, and aniline. These fuels can corrode metal fuel system parts or damage plastic and rubber parts.
Fuel containing metals such as methylcyclopentadienyl manganese tricarbonyl (MMT), which can damage the emissions control system and spark plugs.
Fuel with a posted octane rating of less than the recommended fuel. Using this fuel will lower fuel economy and performance, and may decrease the life of the emissions catalyst.
Every octane booster I've seen has MMT in it or some other prohibited additive.2020 C8 Stingray Convertible - Torch Red - Natural Dipped 3LT - Z51 w/MSRC - Front Lift
Originally posted by MidEngine View PostThose are good options for those who choose but candidly other than on the race course if then and other than from time slips at the drag strip your butt dyno is not going to be able to tell the difference between your power at 91 vs 92 vs 93 octane.
I can feel the difference when I use octane booster in another mid 400s hp car vs 91 octane alone. Maybe you can't.
If you are the sort who enjoys the "kick in the pants" feel when playing hard with your car then give it a try. If you're the sort who enjoys going slow in the slow lane and never exceeding 3500rpm then you''ll probably not feel a thing.
To thine own self be true. Decide who you are and act accordingly.
You've spent lots of money on a very high performance car. Can you live with knowing you're only getting "reduced performance" from it?
Act on that knowledge.
- 1 like
I've used both and can't tell the difference between 91 and 93. Here in MO. BP sells 93 octane without ethanol added, I use it, but no change in performance from 91 with up to 10% ethanol that I can tell, since I discovered the 93 speed juice.
Performance will be reduced ONLY if the engine knock sensors detect pinging and retard the timing. In most conditions, even brief full throttle runs probably won't cause detectable pre-ignition. In very hot weather, if the engine is heavily loaded, or you're running hard enough to really raise engine temps, then yes, timing will be retarded and the difference can be noticeable, if small.Current C7:SunKissed, 2015 2LT, 7MT, Black over Daytona Sunrise Orange Metallic, Stingray convertible
Status 3000: 2021 2LT HTC, Red Mist Metallic Tintcoat, two-tone Natural w/ suede inserts, FE2, NPP Nickname TBD
2021 2LT HTC, front lift, MRCS, GT2 natural Napa 2 tone seats, Perf. exh and all wrapped in Red Mist metallic, lowered w/Paragon collars and riding on BC Forged wheels 😎
Delivered 1/26/21 VIN 00921
- 2 likes
But the LT1 is not a "regular engine" specifying 87 octane fuel. It is high compression engine requiring premium fuel as per Chevrolet.
If you use lower than recommended octane fuel and the knock sensors detect it, the engine will adjust ignition timing and likely also fuel richness to curtail the knocking. This will lower the available horsepower, depending on how much adjustment the computer deems necessary. It may also adversely impact fuel economy.
Originally posted by Milliwatt Rob View PostBut the LT1 is not a "regular engine" specifying 87 octane fuel. It is high compression engine requiring premium fuel as per Chevrolet.
If you use lower than recommended octane fuel and the knock sensors detect it, the engine will adjust ignition timing and likely also fuel richness to curtail the knocking. This will lower the available horsepower, depending on how much adjustment the computer deems necessary. It may also adversely impact fuel economy.Current C7:SunKissed, 2015 2LT, 7MT, Black over Daytona Sunrise Orange Metallic, Stingray convertible
Outbrain
Adnimation Footer
