Corvette Today Podcast With Keith Cornett/“CorvetteBlogger”
Steve Garrett and Keith Cornett from CorvetteBlogger.com combine once again to bring you the latest news and headlines in the world of Corvette!  https://anchor.fm/steve-garrett/epis...er-2020-el5mlj Some of the topics you'll hear about are:
1.  GM delivers 6,355 C8 Corvettes in the 3rd Quarter
2.  Callaway offers a 25th Anniversary Special Edition for C7 Z06
3.  2020 C8 Corvette named Car Of The Year by Popular Mechanics
4.  Chevrolet announces that C8 production extended thru the end of the year. 2021 production starts in December.
5.  EV Hybrid may replace the Grand Sport in the C8 lineup
6.  2022 C8 Z06 spied at Grattan Raceway with rear wing and newly exposed wheels
7.  Corvette Racing using 3D printed parts
8.  What the reveal of the C8 lineup tells us about the future of Corvette
9.  Guess what Batman’s daily driver is!
Be sure to check out this edition of CORVETTE TODAY!
Lug Nut Torque on locking lugs, same or less?
  • Lug Nut Torque on locking lugs, same or less?
    The C8 specifies a sky high 140 ft/Lbs of torque on the wheel lug nuts.
    My mechanic didn’t want to apply that to the GM locking lugs as he was sure it would shear them off. He suggested 90 ft/Lbs.
    Does anyone have personal experience with this, for better or worse?
    I’m not eager to be the trail blazer on stripping the locking lugs!
    Given the 140 ft/lbs requirement, I bought a new, more heavy duty torque wrench. With about 500+ miles on my C8, I checked all lug nuts last week. I found that about 75% were at 140, but some were slightly less. I'm glad I checked them as recommended and probably should have done it earlier.
    I'll admit, I did have some reluctance using a 2-foot long torque wench with the force necessary for 140 ft/lbs on my C8, but it worked fine and I don't think you should be concerned applying the torque specified by GM.
    Delivered 9/5/2020: 2LT C8 Coupe, Long Beach Red, Z51, FE4 Suspension, E60 Lift, Spectra Gray Tridents, GT1 Seats, Jet Black Interior, Splash Guards
      Exactly, as VA_Bill noted, that is if the locking ones are a GM part. Do the cheaper aftermarket ones hold up to 140 PSI? Only time will tell. As to your Tech Denizen not wanting to go to 140 #, that is so wrong — and leaves, him, his dealership and you liable (your safety) if there is a problem later attributed to not having the OEM specified torque on all five studs.
        I would find another mechanic.
        Rocket City Florida
          What other's said. ALL the lug nuts should be torqued to the same value. Always.
          SunKissed, my 2015 2LT, 7MT, Black over Daytona Sunrise Orange Metallic, Stingray convertible (One of about 40)
          Purchased 5/2/2015,
          >36,000 miles
          Proud member of the Old Dominion Corvette Club. Check us out http://www.olddominioncorvetteclub.org
            I just changed over to black lug nuts on my car.I used a set from McGard .They were the spline type and included a locking lug for each wheel.They also included the socket for the locking lug and a socket for the spline lugs. This is the torque wrench I used for the final torquing to 140 ft.lbs. Didn't have any problems. I will check them again after 100 miles. Click image for larger version
              Ha Ha Ha "sky hi torque" ALWAYS use factory torque specs - especially on wheels! My 911 Carrera GTS required 444 ft/lbs of torque - needed a 3' breaker bar (plus a special wrench too). Safety is not up for the tech to mess with.
