So has anyone thought about using a using a little bit of this on their steering wheel as a mod?
1 of 2
ZORA Patrons Now Have Signature Picture Capability
Announcing an additional way for MECF to say thank you to our “ZORA Patrons.” Program now operational. Please see how: https://www.midenginecorvetteforum.c...r-zora-patrons
2 of 2
That steering wheel marker...
Seems like all the steering wheels on the new C8...... EXCEPT if you have a Sky Gray interior, have the centering stripe on the wheel. Every other color combo I saw had a colored stripe.
I asked the GM Rep when I saw, and sat in the car in Hazelton, PA several weeks ago about WHY only the gray interior didn't get the steering wheel stripe, but he had no idea.3LT Coupe, Z51 Torch Red with two toned Red/black interior. 5VM visible CF ground effects, Carbon Flash wheels, engine appearance package and Carbon Fiber interior trim. Mag Ride control. Red Calipers. VQK Splash Guards. Carbon fiber: Steering wheel, mirrors, High Wing, Door handles & boomerangs; Rear Diffuser with vertical diffuser fins; A Pillar; B Pillar; Rear Hatch Side Vents, as well as top camera surround piece and lower under glass piece; Engine bay surround pieces; and front grill trim.
Originally posted by JB View PostMark..looks good. Does it stay on?
the yellow stitching looks good too. Thats a factory option right?
Mark
- Just when you think you can't dig your hole any deeper, they throw the shovel in at you -
- Likes 1
Originally posted by Strake View PostSeems like all the steering wheels on the new C8...... EXCEPT if you have a Sky Gray interior, have the centering stripe on the wheel. Every other color combo I saw had a colored stripe.
Mark
- Likes 1
Humm............ I just went off and tried the configurator and put in a 2 LT trim, with red interior and it showed the steering wheel with the red stripe and red stitching.....
Also, the 3LT tour car ( orange with light gray interior) had NO stripe on the wheel. I also tried several other combos on the configurator with the gray interior, and none had the stripe.
I'm doing a 3LT anyways, but thought I would add what we saw in person.3LT Coupe, Z51 Torch Red with two toned Red/black interior. 5VM visible CF ground effects, Carbon Flash wheels, engine appearance package and Carbon Fiber interior trim. Mag Ride control. Red Calipers. VQK Splash Guards. Carbon fiber: Steering wheel, mirrors, High Wing, Door handles & boomerangs; Rear Diffuser with vertical diffuser fins; A Pillar; B Pillar; Rear Hatch Side Vents, as well as top camera surround piece and lower under glass piece; Engine bay surround pieces; and front grill trim.
- Likes 3
Re the earlier statement, I do not believe that 1LT steering wheels have that center top stripe. Can anyone please confirm or correct me?2023 Z06: Hypersonic Gray HTC, two tone blue interior, CCB’s, 3LZ, E60, and with every visible carbon fiber option order-able including wheels. Lifetime, annual contributors, and 25 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
- Likes 2
>16,000 miles
- Likes 2
When I am turning a a series of sharp, reverse corners, nice at times to have a visual marker available in the corner of my eye should I want.2023 Z06: Hypersonic Gray HTC, two tone blue interior, CCB’s, 3LZ, E60, and with every visible carbon fiber option order-able including wheels. Lifetime, annual contributors, and 25 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
- Likes 1
First used on circle track cars. In steady radius corners, the driver could note the turning angle of the steering wheel. By noting the position of the strip. He can use that to help tune the car. If the car had a lot of understeer, the stripe or turning angle of the wheel would be more for the same corner. If the car had oversteer, the wheel would be turned less and the stripe located higher. This is for constant radius corners . It is very old school, not used now with all the data AQU we have now, but in the old days it was another tuning trick to use. Kinda dumb and unless now, if I had an opinion.3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
- Likes 3
Originally posted by Racer86 View PostFirst used on circle track cars. In steady radius corners, the driver could note the turning angle of the steering wheel. By noting the position of the strip. He can use that to help tune the car. If the car had a lot of understeer, the stripe or turning angle of the wheel would be more for the same corner. If the car had oversteer, the wheel would be turned less and the stripe located higher. This is for constant radius corners . It is very old school, not used now with all the data AQU we have now, but in the old days it was another tuning trick to use. Kinda dumb and unless now, if I had an opinion.
Outbrain
Adnimation Footer
