Easy C7 oil change ..
There are two oil drain plugs on C7’s with the dry sump oil system.Z06 coming late this summer: Hypersonic Gray HTC, two tone blue interior, complete high wing/aero package. CCB’s, with every piece of visible carbon fiber available. Lifetime, annual contributors, and 24 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
- Likes 2
Correct, the drain plug near the front of the pan drains the external dry sump reservoir ( tank ) and the hoses. The drain plug near the oil filter drains the residual ( about one quart ) oil from the oil pan.3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
- Likes 3
Originally posted by Racer86 View PostSame setup on the other 30 million small block chevys
I've never changed the oil in the Corvette before, thanks for letting me know .
P.S. Another day I learn something new ,
Thanks, Scott
Last edited by Ssscooter66; 10-08-2018, 09:26 AM.2022 LT2 Elkhart Blue .. A thought if I might ...
Thanks, Scott3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
- Likes 3
Originally posted by Racer86 View PostSame setup on the other 30 million small block chevysLast edited by Ssscooter66; 10-11-2018, 11:59 PM.2022 LT2 Elkhart Blue .. A thought if I might ...
- Likes 2
Originally posted by Ssscooter66 View Post3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
- Likes 2
Actually, one thing annoys me about changing the oil on this car (and many, many others). You can't remove the drain plug without covering your wrench, and probably your hand, in oil, because the plug is vertical. I've had other cars and bikes with the plug is horizontal, at the very front of rear of the oil pan. When the oil starts to drain out, it flow down, away from your hand and wrench, instead of all over it. A much smarter design.Delivered 5/29!: Scarlet Fever 2021 2LT HTC, Red Mist Metallic Tintcoat, two-tone Naturalw/ suede inserts, Mag Ride, Performance Exhaust, MRR 755 Gunmetal wheels
- Likes 1
Our 2014 Chrysler 300 has its oil filter on top of the engine in a small tank. You unscrew the lid and remove the filter , no oil is spilled. We also vacuum the oil out of the oil pan, from the dipstick tube, so no need at all to go under the car. Many other cars are using the same system.3LT Long Beach Red , Z51, FE4 , ZZ3, Black interior ,38S red stitching, Q8T, FA5, ER1, CFX, and R8C
- Likes 2
Originally posted by meyerweb View PostActually, one thing annoys me about changing the oil on this car (and many, many others). You can't remove the drain plug without covering your wrench, and probably your hand, in oil, because the plug is vertical. I've had other cars and bikes with the plug is horizontal, at the very front of rear of the oil pan. When the oil starts to drain out, it flow down, away from your hand and wrench, instead of all over it. A much smarter design.
pull the rear plug out the same way when they both stop dripping pull the filter this the messy part you must hold on the the filter and do not let fall in the oil pan. You will be sorry if you don't.
I prefill the filter and put it the plugs install the filter and refill with 9.8 qts including the oil in the filter.
- Likes 1
I have met thru car shows a dozen of folks who had their C7s overfilled at dealers while getting an oil change. Now I talk to the service tech before getting mine changed. Charlie aka cutnout aka Charlie
Originally posted by cutnout View PostI have met thru car shows a dozen of folks who had their C7s overfilled at dealers while getting an oil change. Now I talk to the service tech before getting mine changed. Charlie aka cutnout aka Charlie
- Likes 1
Outbrain
Adnimation Footer
