I have always drove manual gearbox transmissions until I purchased my current 2007 coupe. The one thing about the design I never understood was the why GM designed the paddle shifters to work. After a little research I found a post on how to correct the poor design, but it still was not exactly what I wanted, but it work at least make the paddles work like all other paddle shifters. That is to say the left paddle would downshift and the right paddle would be for upshifts, but I still would have those stupid little buttons with the + sign on them unless I cut them off..
I final found a site that sold custom paddles for the C6 and the Camaro. That was the answer to my problem.
So what I did was the remove the steering wheel, and locate the wires going to the paddles. I then simply reverse the two wires that controlled the action of the factor paddles. I them removed the stock paddles and installed the custom paddles.
Here is the site that explains the way to reverse the wiring, http://www.bratten.org/C6/Paddle/index.html
and here is what my shifter look like now.
