Official C8 Build and Price, Visualizer, Pricing, and Ordering Information
Coupe/HTC Build & Price: https://www.chevrolet.com/performanc...d-price/config
GM’s C8 Info Site: https://www.chevrolet.com/upcoming-v...ation-corvette
C8 Order Guide 1/17 Changes: https://www.gmfleetorderguide.com/NA...D=21905&type=0
Visualize Your C8:https://visualizer.chevrolet.com/ui?...US&channel=b2c
Also please look at our stickies in each of the four major C8 sections
MECF TEMPORARY MAINTENANCE SHUT DOWN
STARTING 4:00 PM (PST), Monday, January 6th: Heads Up Please of Scheduled Maintenance!!!! Unlike past notices when our software company said MECF would be shut down less than one hour, they have said that our forum COULD have a two hour shut down. Thank you very much for your understanding.
Upping Performance of a C5
  • Upping Performance of a C5
    When my 1999 C5 Coupe was new was sent to Chuck Mallett for $25,000 of mods
    Then through the last 21 years added more mods and changes :
    372 Cubic Inches (6.1 Liters) STROKED
    Billet Steel 4340 Chromoly Crankshaft, Nitride Treated, Knife-Edge Aero Counter-Weights
    Billet Steel 4340 Forged Chromoly H-Beam Connecting Rods
    Forged Alum Lightweight Pistons w/ Swain Ceramic Anti-Friction, Heat-Barrier Coating
    Custom Mallett-Spec. Billet Performance Roller Cam (gun-drilled)
    Custom 4340 Chromoly Steel Pushrods
    1.85 ratio rockers
    Custom High-Speed Valve Springs & Lightweight Retainers
    Heads Custom High-Flow Ported/Polished
    Carbon-Fiber Coil/Rocker Covers
    High-Performance Exhaust System - Long Tube Headers
    LS6 Intake Manifold – 38 lb/hr fuel injectors
    Team ZR-1 custom PCM calibration tune
    Donaldson Air Filter - Team ZR-1 Cold Airbox enclosure
    Water – Methanol Injection
    Large Race Radiator - Oil Cooled Via Heat Exchanger
    2 quart AccuSump with remote mounted oil filter
    Team ZR-1 Transaxle and Transmission Cooler
    3.73 Rear End Gear Ratio
    Hand Assembly & Performance Testing
    450 Rearwheel Horsepower @ 5800 RPM NA – 600 HP with 150 shot of NOS
    440 Lb-Ft. Torque @ 4800 RPM NA – 640 FT/lb with NOS
    Z-51 Springs
    Penske/Mallett Double Adjustable Indy-Style Shocks nitrogen cooled
    Mallett-Designed Front & Rear Tubular Sway Bars
    KFP High-Performance Carbon-Kevlar Brake Pads
    Lowered Ride Height (1.5") with bump stops
    Custom Kirban Aluminum Shifter w/ Mil-Spec. Anodized Hardcoat
    Custom Mallett Logo Embroidery on Sports Seat Head Rest
    5 Point Harness Bar - 5 Point Harness belts
    Mallett Exclusive Forged Alloy Wheels
    Front Wheels = 10X18 inches – 275/35/18 tires
    Rear Wheels = 12X18 inches – 335/30/18 tires
    Mini tubbed 2" per side
    Adjustable Rear Wing
    Sports Seats
    Top speed achieved : 237 MPH
    Drags on street tires : 10.94 at 128 MPH
    Corvettes owned, wrenched on and raced since 1975:
    1974,75,77,84,87,89,91,93,94 ZR-1 & 1999 Mallett 435
    WOW. I can not decide which if three things on your car are the most beautiful, e.g., its color, its tire tread pattern, or its overwhelming performance. Guess it is a 3-for-3, “11” — on a scale of 1 to 10.
    GBA Black; HTO Twilight/Tension interior; Z51 & Mag Ride; E60 lift; 5ZZ high wing; 5VM vis CF ground effects pkg; FA5 interior vis CF; ZZ3 engine appearance; 3LT; Q8T Spectra Gray Tridents; J6N Edge Red Calipers; SNG Edge Red Hashmarks; VQK Splash Guards. Separately getting from my dealer RCC Edge Red engine cover, 5JR vis CF mirror caps, and VJR illuminated sill plates.
    Lifetime, annual contributors, and 20+ year members of National Corvette Museum.
    Home is the beautiful Pacific Northwest.
      Just one problem John
      As the saying goes
      If your going to play, you gotta pay ! :-)
      This 99 with all the mods has been a bullet to this day,
      Everything works just fine as of today and the only problem it had was my fault as
      the drag strip maybe near you, Woodburn track
      I was way ahead of the guy I was racing and not to go faster then the ET I dialed in I went to slow down before the traps
      and over rev'd engine on downshifts and bent 2 valves.
      Luck though they did not hit the tops of pistons !
      Anyone who says the Corvettes are clunkers and cheap just have not driven them hard enough . . . .
        Mine did hit the piston , something I'm hoping on never happening again 🍀 \
ID:	102933Click image for larger version
        A thought if I might ...
          **** that hurts, in a lot of ways, esp the bank account
          These below, lucky they are not from my C5
