What were the developments that the LT1 pioneered? As explained in an October 31, 2012 (just days after it was introduced), in this video with John Rydzewski. John was one of the chief LT1 development engineers, and explains many of the features in the 2014 LT1 Corvette engine, including direct injection, continuous variable valve control, the rotating assembly, engine block, intake manifold, 11.5:1 compression ratio, and combustion system. Thanks to popularhotrodding for this video.
Z06 Pricing Spreadsheet: https://www.midenginecorvetteforum.c...9Chvp%E2%80%9D
LT1 Enhancements Revisited
2023 Z06: Hypersonic Gray HTC, two tone blue interior, CCB’s, 3LZ, E60, and with every visible carbon fiber option order-able including wheels. Lifetime, annual contributors, and 24 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.Tags: None
- Likes 1
Thank you. The LT1, Naturally Aspiration, is tied and true. The LT 2 will tap the deeper potential. We will soon see how far they went.
This engine will run with the DCT exclusively. At least at first. WE will observe that the LT2 is designed to exploit the strength of the 8 gear DCT. but just how. Economy? Performance? Reliability? What emphasis and balance?
- Likes 1
Great questions SheepDog, for we sure do not know on which end of which continuum GM is wanting to “push.”2023 Z06: Hypersonic Gray HTC, two tone blue interior, CCB’s, 3LZ, E60, and with every visible carbon fiber option order-able including wheels. Lifetime, annual contributors, and 24 year members of National Corvette Museum. Home is the beautiful Pacific Northwest.
All the GM direct injection engines since 2014 are solid! Better efficency over the the Ls engines w/ port injection. I had then supercharged both the ls3 and ls7. Also had the Ls 9 I think the Lt4/Lt5 are the best engines
GM has made to date . I think they run the same crank and pistons except the LT5 has a wider keyway for a stronger crank balancer securement
along with a different cam. I had an Lt1 in my 2014 Z51. It was the victim of a bad tune after a blower install. I think maybe a ring broke since oil use was extreme. I sold the car at a big loss. I do think the lt1's are a good engine. I have two 5.3's in 2015 and 2018 GMC trucks and they have been very good engines.
The Lt4 has the forged internals, stronger pistons and are more robust than the GM N/A engines. The lt4 is fantastic and better than stock when paired with 2300 heartbeat blower which is a game changer over the GM blowers.
The lt4/5 GM Blowers both tie the intercoolers directly to the charger case where the Maggy design does allow them to directly touch the case allows them to cool better. The flow though design is better as well. The Maggy blowers have better efficiency and run cooler and save weight over both the 1.7 and 2.65 GM blowers.Last edited by 3 Z06ZR1; 04-20-2019, 01:02 PM.
- Likes 2
Outbrain
Adnimation Footer
