If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
The 2 Z06's both the M7 and the A8 are stronger than a stock ZR1 incredibly fast on just pump gas. The A8 is just nuts on the on ramps. The base has the Halltech intake. Top numbers are Halltech 2300 headers Zr1 tb, About 100-120 rwhp over stock A8's
Impressive results. All told how deep are you into the cost of mods on the z06?
10 or 15?
Seems like you have quite the duo.
thanks for sharing.
If you know where to shop you are easy under 7k for everything. DIY just need someone to lend a hand when you swap the blower.
Runs cooler as well! This is with the standard 80 mm pulley.
Then the easy 26 MPG I pulled. It is better a car than any Corvette Gm produced to date. The Car Gm should have made.
Just weighed my A8 yesterday. It weighed right at 3507 full of fuel on my corner scales. This is about 40 pounds less than stock with the reduction in weight coming from the headers and lighter weight Supercharger off the front end. The car with the 650 rwhp/ 650 rwtq is just incredibly fast. Runs noticeably cooler than stock as well. A real hoot all on pump gas. 51 percent of the weight on the rear too!
The manual M7 with the same mods weighed 3523 so the Auto is a little bit lighter than the manual car.
